  • 61 رأی - میانگین امتیازات: 3.15
دانلود نرم افزار SeismoStruct - Version 7
Hope all is well with you dear Iransaze friends.
New version of SeismoStruct is now available
Version 7 of award-winning SeismoStruct has just been released, featuring the following new major analysis/modelling capabilities:
1) Response Spectrum analysis
2) CAD-based Building Modeller (Note: not available in academic version of the program)
3) Batch Analysis Facility
4) Automatic calculation of shear and chord-rotation capacity for frame elements
5) User-defined strength degradation for frame elements that reached their shear capacity
6) Multiple options for transforming masses to loads, and vice-versa
7) Distributed loads for frame elements
Moreover, SeismoStruct v7 features also a myriad of additional novel features, such as:
New elements, section types and material models:
1) Computationally-efficient displacement-based plastic-hinge frame element; 'infrmDBPH'
2) Streamlined definition of reinforced concrete sections (cover concrete no longer needs to be specified by user)
3) Possibility of using different steel material for existing and new rebars in reinforced concrete jacketed sections
4) Longitudinal reinforcement patterns in 'rcrws', 'rclws', 'rcuws' and 'rcbgs' section types
5) European rebars library augmented with 24/26 mm diameters
6) Double angle/channel shape section ('dacss') and composite rectangular section ('crd')
7) Predefined W and HSS steel sections
8) Dodd-Restrepo steel model ('stl_dr')
9) Automatic FRP jackets confinement factor computation
10) User-customisation of Modulus of Elasticity for all concrete material models
New pre-processing features:
1) Graphical input facility for nodal and element loads
2) Simpler but more informative 'Add Material Class' module
3) Font size adjustment in 3D model plot node/element labels
4) Possibility of adding additional node/element to an existing Group
5) Graphical point&click selection of sectional stress/strain monitoring points
6) Infill response curves are now visible only when defining an infill panel element
7) Selection of rebar size typology (European or US) is now independent from Units selection (SI or English)
8) Applied Loads module is now active when Eigenvalue analysis is selected (so that masses can be defined from loads)
9) Wizard-generated models feature 'infrmFBPH' frame elements (computationally more efficient than their 'infrmFB' counterparts)
New post-processing features:
1) Stress and strain output in Incremental Dynamic Analysis
2) Possibility for users to define which performance criteria is visualised in the 'Deformed Shape Viewer'
3) Graphical 3D/2D visualisation of internal forces for each single element (accessible by clicking an element in the 'Frame Forces Viewer' module)
General updates and bugs fixes:
1) Updated Help Systems and User Manuals, which now feature a 'Getting Started' section with plenty of model creation tutorials (corresponding tutorial videos also released online)
2) The position of the longitudinal rebars in R/C sections now considers the stirrups' width
3) Corrected problem in IDA when the ratio between the number of analysis steps and output frequency was not an integer
4) Replaced 'sec(0)-sec(3)' with 'sec(1)-sec(4)' in analysis log file
5) Corrected bug in definition of stress/strain monitoring point
6) Removed numerically unstable material models
7) Addressed other minor bugs
Download SeismoStruct - Version 7
http://www.seismosoft.com/Public/Downloa...ild100.zip
Visit Seismosoft.com or my website for much more detail.
Good Luck Friends.][/align][/align]
salam
in narmafzar codesh baz hast ya na ?
man download kardam vali azam licenc mikhad!!
chejori mishe craksh kard
کرک برنامه موجود هست ؟
  دانلود نرم افزار Simulia Abaqus 6.14-1 admin 4 4,498 1398/7/14 ، 03:38 صبح
  دانلود نرم افزار Ansys 15.0.7 x86/x64 admin 1 4,153 1396/11/3 ، 04:32 صبح
آخرین ارسال: سیدحجت
  دانلود نرم افزار Perform 3D v6 mahmoodimr 0 831 1395/10/7 ، 05:26 عصر
آخرین ارسال: mahmoodimr
  دانلود برنامه آنالیز شتابنگاشت های زلزله SeismoSignal فرشاد امن خانی 7 11,897 1395/2/22 ، 08:39 صبح
آخرین ارسال: reezafly
  دانلود نرم افزار طراحی تونل plaxis 3d tunnel فرشاد امن خانی 0 3,267 1393/5/3 ، 11:16 عصر
  دانلود Plaxis Professional v8.5 - نرم افزار رشته مهندسی ژئوتکنیک (خاک و پی) فرشاد امن خانی 0 1,413 1393/4/18 ، 08:31 عصر
