  • 24 رأی - میانگین امتیازات: 3
خبر: ایتبس 2016 با قابیلیت های جدید در راه است...
لینک خبر
https://www.csiamerica.com/products/etabs/releases
[تصویر:  5u0oiztv0fbscjqc90xj.gif]
Modeling of PT Tendons
Model PT tendons and allow consideration of post-tensioning in the design of concrete slabs within ETABS.
[تصویر:  ETABS_2016_Modeling_of_PT_tendons2.png]
Slab Design Based on Strips
Model slab design strips that can be used
for concrete slab design, within ETABS. American, European, British,
Canadian, along with several additional international codes are
available.
[تصویر:  ETABS_DesignStrips.png]
Punching Shear Check
Punching-shear design checks in concrete
slabs at columns and load locations specified by the user. Overwrites
for punching perimeters can be added as well as specifiying openings
which affect the perimeter but are not explicity modeled.
[تصویر:  Display_of_punching_shear_check_full.png]
Design Reports for PT Stresses
[تصویر:  Design_reports_stresses.png]
Design Reports for Flexural and Shear
Slab Design Based on Area Finite Elements
[تصویر:  SlabDesign.png]
Modeling
Add Insertion Point Assignments to Slab or Wall Elements
Apply thickness overwrites on a
joint-by-joint basis, allowing slabs and walls to have nonuniform
thicknesses. Joint offsets can also be applied.
[تصویر:  shell_assignment2.png]
Interface added to define soil profile data for Soil Structure Interaction of Footings
Generate spring and dashpot properties under footings to model soil-structure interaction.
[تصویر:  uplift-iteration.png]
Parametric PMM Hinges for Frame Elements
Loading
Automated Wind and Seismic Loads added for NBCC 2015
Wind loads include torsional moment.
[تصویر:  wind-russian.jpg]
Automated Response-Spectrum Functon added for NBCC 2015 and Russian Code
[تصویر:  auto_response_spec_russian.png]
Analysis
Event-to-Event Strategy
Pure event-to-event stepping solution implemented as an option for nonlinear direct-integration time-history load cases.
[تصویر:  EventToEvent.png]
Automated Floor Vibration Analysis for Heel Drop Effects for Long Spans
Define vibration analysis paths on floor
slabs, along with parameters defining demand and capacity. Automated
time-history analysis is performed for each case.
[تصویر:  heel-drop.png]
Energy Plots for Direct Integration Time History Analysis for Performance-based Design
Step-by-step energy plots and tabular
results available for nonlinear direct-integration time-history load
cases and for nonlinear static/staged-construction load cases.
[تصویر:  Energy%20Plot.png]
Design
Russian Concrete and Steel Frame Design Codes Added
[تصویر:  russian_concrete_code_horizontal_trans.png]
Output and Display
Story Plots
Animated plot shows story accelerations,
drifts, shears and overturning moments together on the same plot for
time history and nonlinear static load cases.
Release Date
25 Nov 2015
ETABS 2015 15.2.0 | 15.2.2 Enhancements
Release Notes
برای دسترسی به فایل باید عضو سایت شوید (کلیک کنید) | [URL=] برای دسترسی به فایل باید عضو سایت شوید (کلیک کنید)
International Design Codes
  • Shear-Wall Design Report- Eurocode 2-2004 enhancement to report wall unbraced height used for computing pier buckling load capacity.
  • [تصویر:  Eurocode_Shear_wall_unbraced1.png]Design Detail Report
  • Material Library - Russian material library updated.
  • Slab/Beam Design
    - CSA S16-09 and CSA S16-14 enhancement limiting the total effective
    width of the slab to 1/4 the span of the beam and taking in account the
    amount of deflection caused by shrinkage of the concrete.
  • [تصویر:  CSA_Deflection.png]Design Preferences
Output and Display
  • Database tables reporting story and diaphragm maximum and average drifts.
  • Drifts now reported at brace locations.
  • [تصویر:  Drift_max_avg.png]Database Table for Diaphragm Max/Avg Drifts
External Import/Export
  • Export of AutoCAD .dwg files for AutoCAD versions 2015 and 2016 now available.
  • [تصویر:  DWG3.png]ETABS model exported to AutoCAD
Enhanced Application Programming Interface (API)
  • Plugins written to access API (Application Programming Interface) now accessible within ETABS.
  • [تصویر:  API%20Plugin1.png]Plugin Window
Chinese Version
  • Tailored summary report now provided for the Chinese version of the program.
  • Results of three methods in
    "Frame Overturning Moments in Dual System" now included in database
    table for the Chinese version of the program.
Release Date
28 Jul 2015
ETABS 15.1.0 Enhancements
Release Notes
Modeling
  • A new 2-D modified Darwin-Pecknold concrete model
    has been added to the nonlinear layered shell. This model represents
    concrete compression, cracking, and shear behavior under both monotonic
    and cyclic loading, and accounts for crack rotation.
[تصویر:  layered-shell_1.png]
Nonlinear layered shell results
[تصویر:  layered-shell_2.png]
Layered shell definitions
  • Time-dependent creep, shrinkage, and stiffness
    behavior has been added for the CEB FIP-2010 and ACI 209R-92 codes and
    for user-defined curves.
[تصویر:  creep_shrink_plots_2.png]
Creep and shrinkage deflection over time
  • Notional size for time-dependent creep and
    shrinkage behavior is now specified on the section properties rather
    than at the material level, and can be automatically computed or
    user-defined.
[تصویر:  Notional_1.png]
Section notional size definition
Loading
  • Automated seismic lateral loading has been implemented for the Dominican Republic R-001 code.
[تصویر:  Dominican_Seismic.png]
Dominican Republic seismic loading definition
  • Automated response-spectrum functions have been
    implemented for the following codes: Costa Rica Seismic code 2010,
    Ecuador (NEC-SE-DS 2015), Mexico (CFE-93 and CFE-2008), and Peru (NTE
    E.030 2014).
[تصویر:  Response_Spectrum_Eduador.png]
Ecuador response spectrum definition
Analysis
  • A new stability check has been added for nonlinear
    static load cases to report when the structure may have failed under
    material or geometric nonlinearities that are not obvious from the
    analysis results.
  • The speed of nonlinear static and nonlinear direct
    integration time-history analysis has been increased for models
    containing many linear shell elements.
Design
  • Several enhancements have been implemented for composite beam design to increase productivity and to improve reporting.
[تصویر:  Compsite_bean_deign_updates.png]
Interactive composite beam design
Release Date
23 Feb 2015
ETABS 2015 Enhancements
Release Notes
Introducing Automation of Performance-Based Design
Performance-Based Design (PBD) is a major shift from traditional
structural design concepts and represents the future of earthquake
engineering. These new procedures help assure that the design will
reliably meet a desired level of performance during a given earthquake.
The fundamental component of PBD is nonlinear dynamic analysis
where an attempt is made to capture the real behavior of the structure
by explicitly modeling and evaluating post-yield ductility and energy
dissipation when subjected to earthquake ground motions. ETABS 2015
introduces new special purpose options and algorithms for the practical
and efficient application of these procedures.
  • Automated PBD hinges and procedures based upon ASCE 41-13
  • Steel and concrete fiber models for shear walls and columns
  • Stable and Fast Nonlinear Analysis (FNA) implemented for PBD
  • Automated Nonlinear hinges in shear walls based upon user/design reinforcing
[تصویر:  ETABS-2015-Shearwall-Fiber-Hinge.png]
Shearwall Fiber Hinge
[تصویر:  ETABS-2015-Wall-Reinforcement-Definition.png]
Wall Reinforcement Definition
  • Steel and concrete material models with performance levels (confined and unconfined)
  • Material strain as performance measure for D/C ratios
  • Automated generalized displacement constraints for strain evaluation
[تصویر:  ETABS-2015-ucac.png]
Unconfined and Confined Concrete (compared)
[تصویر:  ETABS-2015-cc.png]
Confined Concrete
[تصویر:  ETABS-2015-s.png]
Steel
  • Several new hysteresis options for nonlinear hinges
  • Options for hysteretic stiffness and strength degradation
[تصویر:  hysteresis-loop-models.png]
Hysteresis Loop Models
  • Output averaging of responses over several time history runs
[تصویر:  ETABS-2015-Avg-Output.png]
Response Averaging
  • Quasi-static (Dyanmic) option for Static Pushover analysis of complex models
  • D/C ratio plots and tables for fast performance evaluation
[تصویر:  ETABS-2015-DCRatios.png]
Demand/Capacity Ratios
[تصویر:  ETABS-2015-Results.png]
PBD Results
  • [تصویر:  ETABS-2015-brb.png]
    Automated Bucking Restrained Brace (BRB) modeling (Star Seismic)
  • [تصویر:  ETABS-2015-ring.png]
    Friction-spring hysteretic damper and Bilinear Maxwell oil damper property
New Graphical User Interface
  • Fast DirectX graphics with full display, drafting and selection capability.
  • Customization of toolbar and shortcut keys.
[تصویر:  ETABS-2015-dx-1.png]
[تصویر:  ETABS-2015-dx-2.png]
[تصویر:  ETABS-2015-dx-3.png]
New Advanced Modeling Options
  • Spectral matching of time history functions
  • Generation of artificial earthquakes using spectral matching
  • Multiple mass sources for nonlinear analysis
  • Modification of geometry by mode shapes for imperfection analysis
[تصویر:  ETABS-2015-Artificial-Earthquake-Generation.png]
Artificial Earthquake Generation
[تصویر:  ETABS-2015-Frequency-Content-Matching.png]
Frequency Content Matching
[تصویر:  ETABS-2015-Multiple-Mass-Sources.png]
Mulitple Mass Sources
New International Frame Design Codes
  • Composite Beam Design - Enhanced User’s Interface
  • Composite Frame Design - Canadian CSA S16-14
  • Concrete Frame Design - ACI 318-14, CSA A23.3-14, and KBC 2009
  • Steel Frame Design - CSA S16-14, and KBC 2009
[تصویر:  ETABS-2015-Composite-Beam-Design.png]
[تصویر:  ETABS-2015-Composite-Beam-Design-Checks.png]
Composite Beam Design Checks
New International Shear Wall Design Codes
  • Design Codes: ACI 318-14, CSA A23.3-14, and KBC 2009
[تصویر:  ETABS-2015-shear-wall.png]
New International Loading Specifications
  • Automated response-spectrum functions for Argentina, Chile, Colombia, Dominican Republic,
    Ecuador, Guatemala, Mexico, Peru, and Venezuela
[تصویر:  ETABS-2015-International-Loading-Codes.png]
  • Additional API support for design data and results
[تصویر:  documentation_0.png]
من طبق روشی که توی سایت ایران سازه گفته شده من ایتبسم رو ارتفا دادم از سایت اضلی شدش
  کنترل و طراحی دیوار برشی در ایتبس 19 SHAKIBA-am 0 158 1402/5/8 ، 03:15 صبح
  همچنان مشکل قفل نشدن ایتبس بعد انالیز 7mycivil 6 4,639 1401/6/22 ، 11:15 صبح
  مشاهده نتایج طراحی در فایل ذخیره شده ایتبس M_Fzl 1 713 1401/6/11 ، 02:55 عصر
  پرسش و پاسخ در مورد ایتبس roza12341234 5 2,017 1401/4/12 ، 11:28 صبح
  مشخصات آرماتورگذاری تیر در ایتبس eng-askari20 0 559 1401/3/28 ، 09:59 عصر
آخرین ارسال: eng-askari20
  راهنمایی نامگذاری مقاطع ایتبس reza_mj63 9 8,694 1401/3/7 ، 05:16 عصر
آخرین ارسال: Shahin.barzgaran
  Etabs 2016 مدلسازی باکس پله و آسانسور در ایتبس hadi2021 1 831 1400/12/7 ، 01:41 عصر
Wink Etabs 2016 نصب نشدن ایتبس 2016 در ویندوز 10 اینترپرایز bkiany 4 4,945 1400/11/21 ، 11:59 عصر
آخرین ارسال: anon
  چطور ایین نامه 318-14 رو در بخش دیزاین ایتبس اضافه کنم به دیزاین کد yasinnarmashiri 1 1,346 1400/8/25 ، 01:40 عصر
آخرین ارسال: سعیدبهادرفر
Lightbulb انتخاب واحد در ایتبس فرخی 1 1,160 1400/8/8 ، 08:11 عصر
