  • 26 رأی - میانگین امتیازات: 2.46
دانلود برنامه تبدیل فایل ایتبس به سپ و بلعکس Convert SAP2000 to ETABS or ETABS to SAP
[تصویر:  mryvoyqf7kzez6ekepca.gif]
توضیحات برنامه
This page describes a tool that can be used to convert ETABS 2015 models into SAP2000 v18 models, and vice versa.
On this page:
Overview
Usage
Supported Data Transfer
Download
Overview
The ConnectSAP2000v18andETABS2015 tool can be used to convert ETABS 2015 models into SAP2000 v18 models, and vice versa. In order to use this tool, the user must have both ETABS 2015 and SAP2000 v18 installed on the same system. Using the latest versions of all CSI products is recommended, but the tool will work with any versions of ETABS 2015 and SAP2000 v18. Both 32-bit and 64-bit versions are supported.
Usage
مراحل تبدیل فایل در برنامه
Run ConnectSAP2000v18andETABS2015.exe
Select an option, either “SAP2000 to ETABS”, or “ETABS to SAP2000”.
Follow the instructions in the title of each of the subsequent “Open File” dialog boxes.
First, you will select the program executable from which you are converting (either SAP2000.exe or ETABS.exe usually located in .../Program Files/Computers and Structures/[PROGRAM NAME]).
Next, select the model file to be converted.
Finally, select the program to which you are converting.
The ConnectSAP2000v18andETABS2015 tool will launch the first program, open the model, then launch the second program and transfer model data.
It will save the new model with the same name as the original.
[تصویر:  uqhgb9jyg2nzjvkt2ka4.gif]
منبع
.zip   ConnectSAP2000v18andETABS2015Launch.zip (اندازه: 1.02 MB / تعداد دفعات دریافت: 257)
 سپاس شده توسط sotoodeh ، keiivan ، manavistone1 ، mehdipanahi ، drmarjanhadad2 ، ehdasgostar
فايل وجود ندارد فقط يه پوشه خالي دانلود مي شود
 سپاس شده توسط ebrahimkazemi51 ، manavistone1 ، drmarjanhadad2 ، ehdasgostar
لینک اصلاح شد
 سپاس شده توسط manavistone1 ، drmarjanhadad2 ، ehdasgostar
وااای ممنوووووووون خیلی دنبال این برنامه بودم
 سپاس شده توسط drmarjanhadad2 ، ehdasgostar
ممنون از انجمن خوبتون برنامه خیلی عالی بود
 سپاس شده توسط ehdasgostar
ممنون خیلی خوب بود موفق باشید
  کدوم نسخه از ایتبس رو پیشنهاد میکنید؟ samisoft 4 6,403 1400/8/28 ، 08:45 عصر
آخرین ارسال: Arya68
  مشکل کرک نشدن ایتبس RASOUL.1369 14 13,374 1400/1/19 ، 12:13 عصر
آخرین ارسال: dvdhz
  روش کرک Etabs 9.7.4 بصورت فیلم علی خیرالهی 44 79,350 1399/6/29 ، 08:39 صبح
  دانلود کرک ETABS 2013 ( تست شده ) admin 81 70,821 1399/5/20 ، 10:37 عصر
آخرین ارسال: ebrahimkazemi
  دانلود تمام ورژن های ایتبس به صورت یکجا (Collection Etabs) فرشاد امن خانی 3 9,606 1399/4/24 ، 10:37 صبح
آخرین ارسال: Shahinsh7
  دانلود نرم افزار ایتبس 2016 Etabs با قابلیت های ویژه + کرک فرشاد امن خانی 7 8,762 1399/3/9 ، 01:21 عصر
آخرین ارسال: اصغر1347
  مشکل کرک کردن etabs 9.7.4 uveper 368 206,121 1398/11/27 ، 01:23 عصر
آخرین ارسال: z.brk
  دانلود نرم افزار CSI Detailing (ترسیم نقشه ی اجرایی سازه بتنی از ایتبس) فرشاد امن خانی 1 5,904 1398/4/24 ، 04:16 عصر
آخرین ارسال: samisoft
  اجرا نشدن برنامه etabs ver 9.7.4 vahid131 46 26,578 1397/10/23 ، 01:57 عصر
  مشکل در نصب 9.7 etabs mose 15 13,630 1397/7/2 ، 01:41 صبح
آخرین ارسال: pooladdel.amin
